05-24-2022
23:59
09:49
DavideFitbit
05-24-2022
23:59
09:49
DavideFitbit
My Charge 5 vibrates noisily and wakes me up when it is fully charged overnight can I turn this off please?
Best Answer05-28-2022 01:14
05-28-2022 01:14
Thanks David much appreciated
09:48
10:09
05-25-2022
09:48
10:09
Hi, welcome to the Fitbit Community forums, @Burtram.
Thank you for sharing your inquiry about the Charge 5.
There is no way to manually turn off the vibration that you get when the device reaches 100% charge (a specific setting on the device or the app), but the brief notification that you get should be not be too strong to wake you up every time. In addition, you can also try turning on the Do Not Disturb Mode or the Sleep Mode on your Charge 5, as these settings usually turn off all notifications and vibrations on the Charge 5.
I'll be around.
05-28-2022 01:14
05-28-2022 01:14
Best Answer06-03-2022 07:48
