There is not an option for walk under the exercise mode with the Charge 5. You have to use the phone app to get this option The Charge 3 had a walk option and I would think the Charge 5 should have this option
Best AnswerHello @Reid0909
Walk is an Exercise Shortcut option on your Charge 5.
If it’s not already on there you can load it through the App on your phone and then use it directly from your tracker.
Go to the Today Screen in the App on your phone, tap your profile picture then Charge 5. Select Exercise Shortcuts. Delete one you don’t need by swiping left then tap +Exercise Shortcuts and select Walk.
Sync your Charge 5 until it turns up under Exercise Shortcuts. You can then start and stop your sessions directly from your tracker in future.
I hope that helps to solve your problem.
