11-18-2023
16:46
09:05
CrisVillaFitbit
11-18-2023
16:46
09:05
CrisVillaFitbit
After two years, I thought I would try using the water lock feature in an aqua fitness class. Big mistake. It’s dead. Do I have any recourse?
Moderator edit: edited title to clarity
11-19-2023 09:04
11-19-2023 09:04
Hello, @Squeebs Welcome to the forums!
I understand your situation with the water lock feature, can you describe in detail what has happened and if you have tried any step to solve the situation, please? Also, please let me know the following:
- Does the Charge 5 vibrate when you connect it to the charged?
- Are the green lights in the back of it on or off?
- Can you try doing a restart following the steps in this article, please?
Thanks for your efforts!
Best Answer11-20-2023 07:05
11-20-2023 07:05
Thanks so much for your reply. I’m afraid there’s no light, no vibration. The thing seems completely dead. I’ve tried the restart a couple of times I put it in a bag with desiccants, I charged it, all to no avail.
11-20-2023 09:09
11-20-2023 09:09
Hello, @Squeebs Thanks for the information provided and for your efforts too!
I understand the situation with the Charge 5 not charging, can you check this article and make sure you have followed the steps in there, please? Let me know how it goes and what steps you did, since this will help other members in the community too.
Best Answer11-20-2023 09:43
11-20-2023 09:43
Best Answer11-22-2023 12:14
11-22-2023 12:14
The issue is not why my Fitbit Charge 5 isn’t charging but rather that it immediately stopped working when submerged in water (I had set the water lock) and has been dead ever since. Is the company willing to help me since they advertise water lock as a feature that you can use while swimming and it apparently is not?
