01-12-2023
20:17
08:52
DavideFitbit
01-12-2023
20:17
08:52
DavideFitbit
How can I add Zumba and yoga to exercises, instead of swimming and running? Thanks
Best Answer01-13-2023 08:51 - edited 01-28-2023 08:18
Hi, welcome to the Community forums, @mewlac.
Thank you for your inquiry regarding the workout options you mentioned earlier for the Charge 5.
I noticed the Zumba option is not available for the moment, I would recommend that you vote for this idea in the Feature Suggestion board of the Community, since this section is regularly monitored by the team of developers: Add Zumba as a shortcut.
Regarding the option to track Yoga, this option is indeed available as a shortcut for the Charge 5. To do so, you can follow the steps listed here. Keep in mind that you can only have 6 activities at the same time, so if you already have 6, you'll need to remove one in order to add a new shortcut.
In the meantime, for exercises that are not available as shortcuts and were steps are not the best indicator for your activity (like zumba), you can use the Workout option instead.
Hope this helps.
