09-07-2022 07:36
09-07-2022 07:36
my charge 5 will count steps by just moving your arm
Best Answer09-07-2022 08:49
09-07-2022 08:49
Hello @bjgriffin
Yes it is somewhat normal. The Fitbit step counter (or any step counter for that matter) is based on an accelerometer which detect movements, there are some advanced pattern recognition to classify the exercise but basically a consistent wrist movement is counted as a step. Which is normal, if you want something more accurate you need a device that you wear on the leg.
