compatibility
Hi,
Do you know if the Fitbit change 5 is compatible with the mobile phone  "Nokia X10 android 11", thanks for your answer
2 REPLIES 2
Hello @anichat1 and welcome to the Community.  Your phone meets the minimum Android OS requirement, which is Android 10.  That being said, some users will still comment about issues with "compatible" phones.  You can search the Android forum to see if there are issues with your phone.
Laurie | Maryland
Thanks very much Laurie
