09-19-2024 10:04
09-19-2024 10:04
The app for the lasr week has been adding sometimes over 15k+ more steps than whats showing on my device. I tried restarting my device, logging on and off on my app, restarting my app and my phone itself. Every time I open the app and refresh, the step count increases by 5k (even though I only refreshed after 60 seconds). It also counts steps when the tracker is sitting on the counter. How can I fix this?
Best Answer09-19-2024 11:39
09-19-2024 11:39
By chance did you add your phone as a device connected to Fitbit? If so, try disconnecting it. I think it's meant to let you use your phone to count activity if you don't have a fitbit device. So it could be incorrectly adding the extra steps - apparently very inaccurately.
09-20-2024 14:56
09-20-2024 14:56
Hello @ss888
To add to @bobdob 's reply, the way you can check if you added your phone as a connected device in the Fitbit app is:
To remove your phone as a connected device, tap on the phone tile and complete the prompts to disconnect your phone.
Just to clarify, removing your phone as a connected device will not affect how your Charge 6 syncs with the Fitbit app on your phone.
