11-23-2023
07:25
12:10
RodrigoMFitbit
11-23-2023
07:25
12:10
RodrigoMFitbit
How do you change to a different exercise mode after tapping Done on the mode you are on. For example: I am on Bike, tapped Done, but I can't get off Bike to go to a different mode.
Best Answer11-23-2023 12:14
11-23-2023 12:14
@egbrown48 Welcome to the forums. Thanks for reaching out about the exercise app on your Fitbit Charge 6.
I will be happy to help you change exercise modes. When you are done and have finished the training session on the Fitbit Charge 6, swipe right to go back to a previous screen. You can also press the button to return to the clock screen and open the training app to select your new training type.
Best Answer11-23-2023 15:53
11-23-2023 15:53
Thank you, but that doesn't seem to work. When I swipe right I get notifications, when I press the button & return to the clock screen then try to go back to the training app, I just get the bike again. I can' seem to go back to the list of training apps.
Best Answer11-24-2023 01:48
11-24-2023 01:48
You need to go to Execise and swipe up to chose new mode.
11-24-2023 06:50
11-24-2023 06:50
I can't go to Exercise. I can't get off Bike.
Best Answer11-24-2023 07:42
11-24-2023 07:42
Best Answer11-24-2023 14:42
11-24-2023 14:42
Hello @egbrown48
It sounds like your Charge 6 is stuck on Bike, which is not normal.
Have you tried doing a restart on your Charge 6? You can restart from the device's Settings menu or by using the charging cable that came with your Charge 6. If you would like instructions on how to do this, see page 53 of the Charge 6 manual (<-- click link).
Hopefully, this will get your device "unstuck" so the Exercise app will work properly.
Best Answer11-25-2023 07:51
11-25-2023 07:51
Thanks for the help. I think I figured it out.
Best Answer11-25-2023 13:12
11-25-2023 13:12
Hi @egbrown48
Thanks for letting us know that you figured it out.
If you don't mind, would you please share the steps you took? This will be helpful for others who have a similar issue.
