12-08-2024
05:38
06:09
MarioSFitbit
12-08-2024
05:38
06:09
MarioSFitbit
Can I adjust my Charge 6 settings to record basal body temperature hourly through the night?
Best Answer@Mschoen54 Body temperature is for tracking core temperature. The Charge 6 cannot measure a core temperature. You can manually log your core temperature from a mouth, ear, or forehead thermometer by tapping on the green '+', then the manually log temperature option. Certain Pixel phones can measure core temperature and sync with the Fitbit app.
Your Charge 6 doesn't record any data that will appear in that tile. If you want to monitor your core temperature throughout the day, then you must measure it and log it yourself.
Laurie | Maryland
Hello @Mschoen54 and welcome to the Community. Basal body temperature is a core temperature measurement. Fitbits can only record a peripheral skin temperature variation. You skin temperature on your wrist is affected by your environment. Sorry.
Laurie | Maryland
yes, I understand the difference. This new Charge 6 has only been in my wrist for a little more than 24 hours too so may need more data. When that info becomes available on my Fitbit dashboard ( there’s a place for it now but no data), can it adjusted so that I can see hourly temp readings?
Hi @Mschoen54 ! Welcome to the Community ! @LZeeW Thanks for all your support !
@Mschoen54 Thank you for your question regarding temperature measurement.
In order to allow your Fitbit device to estimate your baseline temperature, you'll need to wear your device for at least 3 nights, especially to sleep.
When you wear a compatible Fitbit device to sleep, it checks your skin temperature every minute.
You can find information related to this topic in the next article: How does Fitbit calculate my baseline temperature?
Then, you will be able to see your skin temperature variation and historical data, following the steps shown here.
I hope this serves.
Visit our Discussions board where you can share your experiences, meet people and create new topics.Si ma réponse vous a plu, merci de me féliciter. Si votre question a trouvé une réponse, acceptez la solution.If you liked my answer, give me a Kudo. If your question was answered, accept the solution.FR-EN-SPA.
Laurie | Maryland
