02-19-2024 15:27
02-19-2024 15:27
Hello! I'm a bit confused. At the end of my EDA scan it says I'm not wearing my device on my wrist (and I obviously am). It's recording my pulse and all on the main screen, so it knows I'm actually wearing it properly. I'm confused what the problem is?
Best Answer02-28-2024 02:51
02-28-2024 02:51
Same issue, did u find a fix?
Best Answer02-28-2024 21:32
02-28-2024 21:32
Hi! It started working normally the next day, so I have no idea what happened. I hope it fixes itself for you too!
02-29-2024 01:47
02-29-2024 01:47
If your EDA (Electrodermal Activity) scan is indicating that you're not wearing your device on your wrist despite you wearing it properly, there could be a few potential reasons for this discrepancy:
1. **Sensor Contact**: Ensure that the sensors on the underside of your device are making proper contact with your skin. If there's any obstruction or interference, it may affect the device's ability to detect that it's being worn.
2. **Tightness of the Strap**: If the strap of your device is too loose, it might not be providing consistent contact with your skin, leading to inaccurate readings. Adjust the strap to ensure a snug fit without being too tight.
3. **Skin Condition**: Sometimes, factors such as dry skin or sweat can affect the conductivity of the sensors, resulting in inconsistent readings. Ensure that your skin is clean and dry before wearing the device.
4. **Device Placement**: Make sure that you're wearing the device on the correct part of your wrist as recommended by the manufacturer. Placing it too high or too low on your wrist might affect its ability to detect proper contact.
5. **Software Glitch**: Occasionally, software glitches or bugs in the device's firmware may cause erroneous readings or display incorrect messages. Consider restarting the device or checking for software updates to see if the issue persists. https://menumcdofr.com/menu-nuggets-mcdo/
6. **Contact Customer Support**: If none of the above solutions resolve the issue, consider contacting the manufacturer's customer support for further assistance. They may be able to provide additional troubleshooting steps or offer a replacement if the device is found to be defective.
By addressing these potential factors, you can troubleshoot the discrepancy between the EDA scan indicating that you're not wearing the device on your wrist despite you actually wearing it properly.
02-29-2024 02:34
02-29-2024 02:34
It was my sleeve tattoo, they should put that on the website but I'm sure that would effect sales so it's kept a secret
02-29-2024 02:34
02-29-2024 02:34
It my was tattoo works perfect on my non tattooed arm, thanks for reply anyways
