11-18-2024
15:38
08:15
FatimaFitbit
11-18-2024
15:38
08:15
FatimaFitbit
I've had the device plugged in for 24+ hours. It will not turn on. The button on the side is also not responding. Out of ideas on what to try next....
Best Answer11-18-2024 15:43
11-18-2024 15:43
I've got the same problem with mine - as of last night!
Best Answer11-19-2024 07:24
11-19-2024 07:24
Very interesting...you wonder if a software update could be the cause....
Best Answer11-19-2024 08:18
11-19-2024 08:18
Hi there @grogers11 and @impalatrace! Welcome to the Fitbit Community! It's great to see you here!
Thank you so much for reporting this situation.
Have you already tried to restart your Charge 6's with the charging cable?
If not, please try to do the following:
1. Connect your device to the charging cable.
2. Press the button located on the flat end of the charger 3 times within 8 seconds, holding each press for about 1 second.
Note: If your charger doesn’t have a button, you can instead disconnect your tracker from the charging cable, pause for 1 second, then reconnect it. Repeat 3 times.
3. Wait 10 seconds or until the Fitbit logo appears.
Note: If the device doesn’t restart, wait 15 seconds and try again.
Best Answer11-19-2024 13:00
11-19-2024 13:00
That's what I thought as well, as mine was working fine & had plenty of battery charge & then just died completely - but in saying that the last update I did was at least a week ago. I've tried all the recommended fixes & none of them worked (including going through phone help). New replacement is on its way to me.
11-19-2024 13:01
11-19-2024 13:01
Thanks for suggestions, I tried the above & going through help desk phone calls - nothing worked. Charge 6 is completely dead. Alas new replacement is on its way to me.
Best Answer11-22-2024 13:28
11-22-2024 13:28
Yes, I tried charging it at least 3 times, it will not power on, nor will the button on the side make a vibration. I have several fitbits, the charger is working...so that is not the issue.
Best Answer11-23-2024 14:48
11-23-2024 14:48
I have the same issues. Who did you contact for a replacement?
Best Answer11-24-2024 11:09
11-24-2024 11:09
Best Answer11-24-2024 14:23
11-24-2024 14:23
Hello @Joe369369
Please contact Support (<-- click link) to start the replacement process. Complete the prompts until you get to the option to chat or call.
