09-01-2025 19:07 - edited 09-01-2025 19:32
my tracker doesn’t restart at midnight. I wake up with 17000 steps at 3am and 1800 cal burned. Then during the day I got all of a sudden the 10000 notification and then a couple hours later again, I tried to reset etc but nothing worked so far
Best Answer09-02-2025 11:54
09-02-2025 11:54
I expect you have your phone connected as a fitbit device. Sometimes with that, it suddenly adds a bunch of steps seemingly randomly, often in the early morning. It is intended to count steps with your phone when you are not wearing your fitbit, but sometimes seems to gives excessive steps randomly. If you think that could explain the steps, then okay. But if you want to prevent that from happening again, try removing your phone as a fitbit device. That would have nothing to do with your phone still syncing with your fitbit.
09-02-2025 17:41
09-02-2025 17:41
Best Answer09-05-2025 17:05
09-05-2025 17:05
Mine too. It won’t charge now and it won’t sync to app. I can’t reboot the watch cause it won’t connect to the charger.
