06-18-2024
10:05
14:42
ManuFitbit
06-18-2024
10:05
14:42
ManuFitbit
Recently I have buy Fitbit charge 6 2 months ago and it was working very nicely, but afternoon it showing black screen not turning on. I have tried 3 time holding the button. But it doesn’t work. Please help.
Moderator edit: clarified subject.
Hi @Subhend. Welcome to the community forums.
Thank you for sharing the information about the Charge 6. Sorry that your device is having this issue.
I would ask that you try syncing your tracker with the Fitbit app.
Also, please change the clock face as instructed here: How do I change the clock face on my Fitbit device?
If your device still cannot turn on the screen, restart as instructed below:
Swipe down from the clock screen to find the Settings app. Open the Settings app, restart device > restart.
If your device is not responding:
Plug your device into the charging cable. For instructions, see How do I charge my Fitbit device? Press the button on the flat end of the charger three times, pausing for 1 second between each press. Then, wait 10 seconds or for the Fitbit logo to appear.
Best AnswerPlug your device into the charging cable. For instructions, see How do I charge my Fitbit device? Press the button on the flat end of the charger three times, pausing for 1 second between each press. Then, wait 10 seconds or for the Fitbit logo to appear.
I have try the above method but still don’t turn on the device, when ever I put it in to the charger it vibrates only, the screen stays black only.
I have the same issue with my Charge 6. I have tried the button press routine, and the logo appears briefly after about 10 seconds, then it goes black again. I cannot check battery charge level or anything else.
