07-31-2024 09:14
07-31-2024 09:14
I’m on along hiking trip and several times an hour, my charge 6 vibrates and wants me to do an EDA scan. It’s annoying because it’s hard to make it go away and it runs for my battery in one day. How do I get it to stop?
Best Answer07-31-2024 12:21
07-31-2024 12:21
Hello @kasee
This page has the instructions on how to remove Fitbit apps from your device (<-- click link).
Let us know if you still have problems removing the EDA app.
BTW, I believe the EDA & ECG apps were installed on your Charge 6 by default.
Best Answer07-31-2024 11:35
07-31-2024 11:35
Hello @kasee
That is a very annoying issue. You might see if you can uninstall the EDA app when you go for a hike. You can re-install it when you get home.
BTW, I found that tapping multiple times on the EDA screen will eventually cancel the app and the device will return to the clock face. Tapping on the screen multiple times also works if the ECG app is accidentally triggered.
Best Answer07-31-2024 11:48
07-31-2024 11:48
Best Answer07-31-2024 11:49
07-31-2024 11:49
Thank a for the reply. I’m not sure how to uninstall it and don’t remember installing it to begin with. Can you ping me to some instructions for uninstalling? I’ve searched but don’t find anything.
07-31-2024 12:21
Hello @kasee
Best Answer07-31-2024 21:16
07-31-2024 21:16
Thank you! It’s now uninstalled. 🙂
08-01-2024 15:33
08-01-2024 15:33
Hi @kasee
Thanks for letting us know that you were able to uninstall the EDA app. Hopefully, this will improve your hiking experience with your Charge 6.
