01-23-2024
14:18
05:58
ManuFitbit
01-23-2024
14:18
05:58
ManuFitbit
DATE IS INCORRECT ON CHARGE 6.
Moderator edit: clarified subject.
Best Answer01-24-2024 05:57
01-24-2024 05:57
Welcome to the forums @Knkbears84.
Thank you for sharing the inquiry regarding Charge 6.
Your Fitbit device may show an incorrect time if it hasn't synced or has been unpaired from your Fitbit account.
Please, try to sync the device. If by any chance you are running into syncing issues, see Why won't my Fitbit device sync? or if you need to relink your watch, see How do I set up my Fitbit device?
Also, note that the time on your Fitbit device may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Fitbit device is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I change the time on my Fitbit device?
If none of the above works for your, I recommend changing your time zone to a completely different one, sync your device, put the correct time and sync again.
