04-09-2024
06:45
19:01
AndreaFitbit
04-09-2024
06:45
19:01
AndreaFitbit
I’m a regular build guy, 230 pounds, 5 foot 10. The largest band Fitbit makes is only 8.7”. I love the watch, for for $150. It’s useless if I can’t wear it I need a band that’s the least 11” long. Please!
I recently heard you’ve had hundreds of complaints from men who can’t wear the Fitbit Because the band is a few inches too small. Please correct this problem as quickly as possible.
Moderator Edit: Clarified subject.
@Stp55 , A warm welcome to the Community! Thank you for your message and feedback regarding the size of the wristbands
Thanks! The best place to post your suggestion is the Product Feedback board in the Fitbit community: community.fitbit.com/t5/Feature-Requests/idb-p/features. Please take a moment and give us your comments.
If you find a similar suggestion from another member of the community, you can vote for their suggestion and add your comments. We hope to see you there!
Best AnswerI decided to provide low, cost solution to the small band problem (especially the large band) that comes with Fitbit. For $12.97, you can purchase these comfortable elastic bands, that will even fit around your ankle. Much more comfortable than the original bands. Until Fitbit corrects this problem, here is the Amazon link: https://a.co/d/9SZQnKO. Problem solved !
Best AnswerI decided to provide low cost solution to the small band problem (especially the large band) that comes with Fitbit. For $12.97, you can purchase these comfortable elastic bands, that will even fit around your ankle. Much more comfortable than the original bands. Until Fitbit corrects this problem, here is the Amazon link: https://a.co/d/9SZQnKO. Problem solved !
