04-12-2024 21:21
04-12-2024 21:21
Fitbit 6 it request android 9 and above, in shown on menu. That is why I've brought it 6 weeks ago. My Samsung is an android 9. For only 6 weeks, Fitbit request me an upgrade to android 10. What can I do ? My mobile is runnung well and have no intention to buy a new phone. Sumsung mobile do not provide android upgrade service.
Best Answer04-12-2024 22:41
04-12-2024 22:41
Hi @simonvuo there's nothing you can do short of getting a newer phone. I'm on Android 9 and knew my time to get a newer phone was coming soon. The newer app might have additional features, but if what you have works, then keep using it. According to the Terms of Service, the app can be changed without advance warning.
04-13-2024 01:11
04-13-2024 01:11
You could also install LineageOS (https://lineageos.org/) if your model is supported (or even if it isn't officially supported, you could find unofficial builds). I'm for instance using S5 with lineageos 18.1 (which is android 11).
