02-12-2024
11:52
09:45
FatimaFitbit
02-12-2024
11:52
09:45
FatimaFitbit
not charging fitbit charge 6
Best AnswerHi @MaryFletch.
Have you tried cleaning the contacts on the back of the Charge 6 and also the pins on the charging cable? Also make sure that the pins 9n the charging cable are able to move in and out freely when pushed (they can get stuck and cause issues with the connection).
thanks I did that. makes me crazy, been trying since 600 a.,m.
Best AnswerAlso there is no magnetic pull anymore when you put it on the charger
@N8teGee , Thank you for your help.
@MaryFletch @RM57 , Nice to see you around. Thank you for your messages and efforts.
How are you charging the Charge 6, on a USB port on a pc/laptop or the wallsocket?
If you are using the wall socket, please make sure that the USB adapter is not for quick charge.
I also recommend you to have a look at this: Why isn't my Fitbit device's battery charging?
