Today, when I open the Fitbit app on my Android phone, it tells me I have "No Data". When I swipe down to re-synch, it spins for several seconds (much longer than normal), then gives the message "Couldn't synch your Charge 6. Tap to open help". Tapping does nothing. I noticed that the device icon in the upper left corner has a red dot, which would seem to indicate that there is some sort of notification, so I tap the icon.
That opens a screen that says "Connected to Fitbit", and my Charge 6 "Update available". That "update available" text blinks every few seconds, and I have seen it go into a period of several seconds where it alternates with another message, but it is blinking too fast to read. If I tap on that part of the screen it opens another screen that gives me a status :
- Charge 6
- Synced 16 hr ago
- Firmware Version 66.20001.202.94
Near the bottom of the screen is an area labled "Sync" that says "Sync now" "16 hr ago", and at the right is a red dot with an exclamation point that blinks every couple of seconds. Touching that dot responds with that area of the screen getting a grey background for a second, then returning.
So what to I have to do to get the update and make my app start syncing again?
Hello there @Stuckyville! So good to see you in the Community.
Thanks for sharing with us the situation you are having with your Charge 6 and for trying to solve the problem with the pending update.
Does your Charge 6 still have the issue?
I suggest trying these steps to solve this:
Best AnswerMy stopped syncing at 12:31 am today. No amount of uninstalling, reinstalling software, rebooting my phone a zillion times is making it work. It won’t even shut down when I press the button on the cable. I’m getting really annoyed at this point. It just keeps coming off bluetooth and won’t connect with my phone. Please help!!!!
Hi there @LUV2CARDIO! A warm welcome to the Fitbit Community!
Thank you for letting us know that your Charge 6 stopped syncing yesterday and for all your efforts.
You can try to restart your Charge 6 this way too:
I suggest you follow all the troubleshooting steps from this article too: Why won't my Fitbit device sync?
Best AnswerFatima, support got me reconnected to Bluetooth (had to re-add the device for it to respond to reset) but some of my data still not syncing (sleep, rhr) and yesterdays info not syncing) tech said to give it 24 hours & call back tomorrow if not resolved but I feel like it shouldn’t take so long to “catch up”. Appreciate any ideas you might have!
Hi there @LisaLovesLit! A warm welcome to the Fitbit Community!
Thank you so much for letting us know that your Charge 6 is not syncing.
Which phone model do you have?
I suggest you follow the 11 steps described in this article: Why won't my Fitbit device sync? You'll find a YouTube video tutorial there too. You can always try to restart your phone and tracker too and try to sync again in case the connection is unstable.
08:14
09:14
FatimaFitbit
02-05-2025
08:14
09:14
FatimaFitbit
I had to get on the phone with them. They got it fixed and now it’s fine.
I would tell you what to do, but they had me do so many different things. I
can’t remember which one worked.😆😆😆
Just go ahead and call their customer service they’ll fix it for you. Good
luck!
Thank you so much for updating us on this situation. I'm glad that your Charge 6 is working again! Thanks for your efforts too.
I recommend you visit our discussion forums. There you will find several users who are interested in fitness, healthy eating, or better sleep and who share many tips with each other. They will certainly be happy to see you there.
The Fitbit community is always available to you!
