02-01-2025 15:02
02-01-2025 15:02
Can anyone tell me why my fitbit has stopped mapping my walks/runs correctly. See pic attached. This has only started recently
Best Answer02-01-2025 17:43
02-01-2025 17:43
@Weewhiskey where you see GPS jump around like that usually means the signal was lost and then picked up later at a different location. So you see those weird straight lines. Wearing it too tightly or a super cloudy day will impact the GPS signal strength.
02-01-2025 23:12
02-01-2025 23:12
Best Answer02-02-2025 05:46
02-02-2025 05:46
@Weewhiskey I don't jog with my phone so on the Charge 6 I use the built in GPS. When you use this setting it means charging the device more often as I find for about an hour long jog, it will use up between 20 to 25% battery each time. So it means charging every 3 days.
02-05-2025 11:22
02-05-2025 11:22
I've got a similar issue.
The crazy tracking looks like the GPS signal is dropping out, so it's joining known points with straight lines. If it was a very cloudy day, then the cloud might have affected the strength of the GPS signal.
Having said that, it seems like a common issue so I suspect there's a bug in the firmware. Maybe try restarting the device and see if that does anything?
