03-22-2025
02:02
19:50
EstuardoFitbit
03-22-2025
02:02
19:50
EstuardoFitbit
I keep getting an icon appear at the top of my watch screen on the charge 6 it’s a phone with a slash through it. Any ideas what this means and how do I get rid of it please ? Only recently started to happen and no ideas why ?
04-21-2025 14:44
04-21-2025 14:44
I have tried your solution with just taking the one step to turn location services on for the app. always and it seems to have solved my issue with going in and out of airplane mode and still having the status on the screen stuck on disconnected. Also I am not seeing the disconnected status when I leave the room where my phone is. Thank you so much for coming up with this fix to try! It seems to have fixed it. I am on iOS 18.4.1.
04-22-2025 08:02
04-22-2025 08:02
I may have spoken too soon. I did a workout this morning and went out of range of my phone. It disconnected and showed the disconnected status. When in range again, it didn't automatically reconnect. I did a refresh of everything and got it connected again. A couple of hours later my phone did a Play Store update and Fitbit was one of the apps updated. It disconnected again and won't reconnect again. Back to wiping it again and refreshing. Fun times. I had a Charge 4 before getting the Charge 6, but I think it's time to look elsewhere...
04-22-2025 10:33
04-22-2025 10:33
I just did a Charge 6 update yesterday. Now I’ve been getting the phone with slash at the top of my watch. It doesn’t matter if I’m close to or away from my iPhone. Bluetooth is connected. Does this affect my tracking in any way?
04-22-2025 17:23
04-22-2025 17:23
I've been having the same issue with the Charge 6 showing as disconnected and not syncing with the app. I've tried restarting both the Fitbit and my phone several times. I've deleted the app and reinstalled. I've cleared storage. I've cleared the user date from the Fitbit and resynced it which helps for a while but eventually just disconnects. I've checked that the location is set to always and I've selected the status tray as to not show.
I'm on Android 11 and the Fitbit firmware is 66.20001.214.24
Any help would be greatly appreciated.
04-22-2025 19:25
04-22-2025 19:25
Hey everyone,
Thanks a lot for all the updates you have shared with us so far; it is really appreciated!
Let me confirm that we are actively looking for a solution to this issue and looking forward to getting you all back on track. Since we are still looking into this issue, and as some of you have already found, there is a small workaround. Please do the following:
By doing this, your device might stop popping up this icon. I hope this is helpful for you while we work on getting an actual solution!
04-23-2025 03:04
04-23-2025 03:04
Mine says 'status tray'. Also, I don't think the status is the problem, as it is correctly telling me it is not connecting to the phone and app. As such, it's not getting calls or text notifications or updating my data. I noticed yesterday it disconnected when I was out of range and failed to reconnect. After I reconnected by wiping data in both app and Charge, I noticed location permissions were again displaying an error so I allowed always location again. However, this time I have not reviewed security to update to the new 'more secure Bluetooth' option. Today, when I was out of range, the status notice displayed but when I was in range again it reconnected. I think your issue is a combination of the location permissions and the secure Bluetooth not connecting or reconnecting when it goes out of range.
04-23-2025 03:12
04-23-2025 03:12
I had the same issue yesterday and I wiped everything again and reconnected, doing the same always location etc. However, this time I didn't do the 'review security' bit with the new Bluetooth. It seems to be when you go out of range of the phone, the Charge disconnects but does not reconnect. Today, I've been out of range, and the status alert came up but when I went to my phone it has reconnected. So try and redo what you did, but not the secure Bluetooth bit, and see if this works!
04-24-2025 08:54
04-24-2025 08:54
I have also been having this issue and it started after I updated my Charge 6 two days ago. I have done your workaround for now but look forward to the issue being resolved. My phone operates iOS 18.5
04-24-2025 17:20
04-24-2025 17:20
Thank you! Turning off the “Status Indicator” worked for me!
04-26-2025 15:23
04-26-2025 15:23
Hello everyone, thanks for the heads-up and all the time invested here!
I'm glad to see this is working for some of you. As soon as I get any update in this regard, I'll let you all know.
04-27-2025 12:10
04-27-2025 12:10
I do not want to have to turn off the Status Indicator just to restore normal functionality to my Fitbit. Turning that feature off would likely prevent my Fitbit from showing other important information aside from the false phone disconnection alert this thread is discussing (which I am currently experiencing).
Is a permanent solution being developed so that the Status Indicator simply works as intended?
If this is the intended behavior of the Status Indicator — to show a false disconnection warning every time I wake the Fitbit, despite the phone and watch still communicating properly (such as delivering text notifications) — then I will consent to turning the feature off; however, that would make the feature, itself, essentially useless.
04-27-2025 12:14 - edited 04-27-2025 12:16
Nothing changed with the functionality of my watch or what it displays by turning off "status tray". Thankfully that fixed the problem of the near constant icon of 'phone disconnected' covering up my pulse rate on the watch screen. The only reason (that i know of) that it needs to be connected to the app is so that the app can sync the data from your watch onto your phone. I still get call / text notifications, it still tracks all of my activity like heart rate and steps etc. Once the app is opened and it syncs, that data now is in the app and not just on the watch. Turning off "status tray" only turns off those notification icons on your watch screen.
04-29-2025 00:39
04-29-2025 00:39
This workaround of enabling location at all tomes worked for me. Thank you for posting because I wouldn't have thought about trying it otherwise! I enabled it, synced, and then disabled it back to "when app is used" and am still connected, hoping it would last. I have no idea why a firmware would require the app to have constant location access to stay connected. Such a mess.....
yesterday
yesterday
This happened to me today, It seems like something in the recent fit bit update or something in the app is causing this issue I hope fit bit has their tech department on top of this right away.
