Has anyone found a reliable Milanese strap supplier ? One which actually latches properly into the strap fitting on the pebble. I have tried 4 different Milanese straps and they all pop out, no matter what I try. (Also on my 2nd pebble)
Best AnswerHi have the same issue. I am a dance teacher & I normally wear my fitbit on my ankle, because when formal dancing correctly the arm doesn't move, so no steps. I have done this for years with no problems. Now with the Charge 6, both connections are loose magnets & the bands are constantly popping off. I generally do a 3rd party metal band, but have tried 3 different ones & all pop off constantly. I'm thinking of going back to the Charge 5 just to get rid of the new loose connection.
