Hi everyone, I'm not able to edit sleep log with charge 6 after the recent update. Cleared cache, restarted tracker, forced quit, uninstalled and reinstalled Fitbit app. Is anyone else having this issue?
Best AnswerHello @dscsmbhh
If you're seeing a message that a log exists for the time you're trying to add, go to the previous day's sleep log and look for an Additional Sleep log. There's likely a short sleep log that captured the beginning your sleep. When you delete that additional sleep log, you should be able to add your sleep in the app.
Which version of the Fitbit app do you have? To check,
Also, are you an iOS or Android user?
Best AnswerHi @dscsmbhh
Thanks for letting us know that you found the additional sleep log on the previous night.
I won't tell you how long it took me before I thought to check the previous day's sleep section for the errant sleep log. 🙄 At least, now we both know where to check if we see that message. 😁
