12-19-2023 17:12
12-19-2023 17:12
My charge 6 does not sync automatically and will hardly sync manually. It often goes half way and stops. This is a new problem. It worked until about a week ago. The “push the button 3 times” restart does not work either.
07-04-2024 09:04
07-04-2024 09:04
10-14-2024 08:53
10-14-2024 08:53
The only way I have found to sync is to restart my phone. It is a pain in the butt. I loved my charge 5 but not so much the charge 6. If I could find a different tracker that is water resistant, I would buy that instead.
12-13-2024 05:01
12-13-2024 05:01
Had Fitbit (Charge 6) about a year, no issues then one day would not sync, tried all the things help and everyone recc, no luck. Charges fine but could not achieve reset. App did not show disconnected phone, but Bluetooth would not connect to the unit. Cleaned the charging ports, tried reset, reset worked, Fitbit logo popped up, all fine now.
12-13-2024 07:01
12-13-2024 07:01
12-13-2024 07:07
12-13-2024 07:07
02-22-2025 16:24
02-22-2025 16:24
I'm having the same problem and it just started a week ago. I have to restart my charge 6 everyday in order for it to sync.
02-22-2025 18:03
02-22-2025 18:03
03-17-2025 10:45
03-17-2025 10:45
I’m having this issue as well. Any suggested fixes besides the disconnecting and reconnecting; done this multiple times
03-17-2025 13:06
03-17-2025 13:06
Hi everyone and warm welcome to the new members of the community !
I appreciate your messages, and I'm sorry to hear that you are experiencing troubles regarding the syncing process of your Charge 6 with the Fitbit app.
I understand your feelings about this situation, and I'll be glad to suggest some tips.
Please, firstly verify that your Charge 6 and your Fitbit app are updated :
How do I update the Fitbit app?
How do I update my Fitbit device?
Then, please verify and apply the steps shown in the following help article : Why won't my Fitbit device sync?
Visit our Discussions board where you can share your experiences, meet people and create new topics.Si ma réponse vous a plu, merci de me féliciter. Si votre question a trouvé une réponse, acceptez la solution.If you liked my answer, give me a Kudo. If your question was answered, accept the solution.FR-EN-SPA.
03-17-2025 13:23
03-17-2025 13:23
04-14-2025 04:52
04-14-2025 04:52
Owned mines for maybe 5 months and same thing it does not auto sync to my iPhone Fitbit app and I have to frustratingly manually do it every time even though phone says it’s connected via Bluetooth and manually sometimes it’s works sometimes it dosent but the the craziest thing is I tend to get emailed by Fitbit about my running times etc stats before the Fitbit app can or will give it to me re not stop syncing crazy.
06-01-2025 02:24
06-01-2025 02:24
I cannot help but ask why do you post this useless info? Do you really think that so many people, me included, don't know about software updates? Did you ever wondered whether such a post of yours can be helpful at all?
Charge 6 does stop updating from time to time for me. Yes, complete reset helps. But do you really think that this time-consuming hustle is acceptable? Do you think that people should read several dozens of forum pages in order to resolve this?
Google makes awful products! That's the primary reason people have problems with fitbit
07-10-2025 08:18
07-10-2025 08:18
Mine is doing the same thing. I have a Fitbit 5 and 6 waste of money.
