Charge 6 won’t sync
My charge 6 does not sync automatically and will hardly sync manually.  It often goes half way and stops.  This is a new problem.  It worked until about a week ago.  The “push the button 3 times” restart does not work either.
52 REPLIES 52
Interestingly, the same thing happened to me.
Maybe they fixed something in the software.
Sent from my iPhone
Reset everything from Charge 6, and your app.
I went through everything and nothing worked. The device died completely on
a trip. They are sending me an replacement as under warrently.
Linda Ikuta
Has anyone found a fix for this? I've had the Charge 6 for over 3 months now and is useless. I have to manually sync everyday - only get notifications on my fitbit for an hour or so after then it goes back to just telling the time and doesn't let me know if I'm getting a phone call !!
I've tried everything, reinstall on phone, back to factory on fitbit etc.
I loved my Charge 4, had no issue till the strap connector broke and was forced to buy a new one.
I really want to exchange this one with a charge 5
If it was me I would contact Fitbit via their online chat service and request a replacement.
Mine has sorted itself out so am quite happy with the watch.
I've got so many ticket references, been in contact with them during past 3 months and just keep taking me through same troubleshooting steps.
Oh dear , let's hope you get it sorted soon, as it is frustrating.
I received a charge 6 for Christmas and loved it, but am having the same issues syncing it. Is there a fix?
As far as I'm aware there isn't a fix. You could try deleting the app and re installing. I did this in the first instance and it seemed to sort itself out on its own. As I mentioned in a previous post I tend to leave it to sync on its own rather than do it manually. Hope you get it sorted.
I can’t tell you why, but mine just started syncing correctly one day. It seemed to coincide with when I plugged it into my laptop and charged it that way. I don’t know whether that was correlation or causation, but right after that, it started syncing properly.
Sent from my iPhone
I am still having problems keeping it synced, although it is a little
better. Still have to manually sync it most of the time…but not always.
Very annoying.
Thanks for the help, I’ll try that!
Same situation - had Charge4 for years that just worked.  'Upgraded' to Charge 6 in Jan and it has never synced correctly. After hours to customer support, as I was asking for a refund, they sent another Charge 6. EXACTLY the same issue. To see if it was my phone my husband, (who's never had a fitbit before), installed and started to use it and guess what - it never syncs!  This is 100% a Charge6 Fitbit issue and they don't seem to want to fix it problem.
It's very strange as mine is working fine now. I have a android phone so not sure if this makes a difference although it shouldn't.
Could be, we’re on iOS
I always wonder if Apple want you to use their Apple watch . I could be wrong. It would be interesting to know how many people who have syncing issues have a IOS phone 🤔
I have the exact same issue. My weekly overview is just blank because it does not synchronize on its own, whereas my charge 4 would always be up to date. Manually syncing seems impossible. What is happening?!
That’s an interesting thought. I have an Apple phone and have issues.
Mine not syncing either from yesterdsy. It was working now it is not.
Exactly my situation. So frustrated, I should not have upgraded!
Same issue here since I got the Charge 6, also had the Charge 4 before without a single problem.
The only reliable workaround on my end is to restart the Charge 6 while I have the App opened on my iPhone. After the restart I can manually sync for a few hours before it stops working again.
