01-05-2025 18:53
01-05-2025 18:53
My Fitbit charge 6 will not sync. I have restarted the watch, I've restarted my phone, I've unpaired and re-paired Bluetooth, and I have uninstalled and reinstalled the app. Any ideas how to solve?
01-05-2025 23:35
01-05-2025 23:35
I have the same issue. Have tried pairing from both the Charge 6 and Google phone, but nothing.
01-08-2025 15:51
01-08-2025 15:51
Hello @LAP835 & @Runsofar954
This help page has the recommended troubleshooting steps to try when your Fitbit device doesn't sync with the app (<-- click link)
Although it's not specifically mentioned, some users discovered that they needed to turn off both Bluetooth & WiFi, then turn them back on to get their Fitbits to sync with the app.
01-10-2025
23:40
05:22
FatimaFitbit
01-10-2025
23:40
05:22
FatimaFitbit
I had the same issue. My charge 6 synced at first, then just stopped. It looked like it was trying but never quite got there. I tried everything. Then I remembered my VPN. Switched it off and it’s synced fine ever since. Only thing I can’t sort out is the step massive over count.
Moderator Edit: Word choice
01-11-2025 11:45
01-11-2025 11:45
Hello @lostboy9
Thanks for reminding us that using a VPN can also affect syncing. This information will be helpful to others.
01-13-2025 08:08
01-13-2025 08:08
Not sure how I did it, but when I switched my phone back on after posting the earlier comment, my FitBit was synching.
Thank you for your suggestions 🙂
01-13-2025 12:44
01-13-2025 12:44
Hello @Runsofar954
Thanks for letting us know that you were finally able to get your Charge 6 to sync with your phone. Hopefully, everything will work properly now.
