Double tap to time
ANSWERED
Is there any way to set my charge 6 to go back to the home screen (time) on a double tap? I REALY MISS this feature. It is a watch after all, there should be a quick way to get it there.
1 BEST ANSWER
Accepted Solutions
Welcome to the Fitbit community, @IBKitten!
Just in case you haven't been aware of: You can return to your devices home screen, which is the clock, by a simple press of it's button.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Charge 6, Versa 4, Aria, Aria 2
5 REPLIES 5
Stefan
You Rock!! Thank you Talahthas!
You're welcome, @IBKitten.
If you have any further questions or issues, do not hesitate to come back.
Stefan
Great idea. But the button doesn't work. Face is stuck on a Timer I don't want.
Hello @SD42
Have you had a chance to try to restart your Charge 6? Since it seems that your display is stuck, you'll need to use the charging cable that came with your device to restart your Fitbit. This help page (<-- click) has the steps to follow.
