01-02-2024
02:39
10:59
RodrigoMFitbit
01-02-2024
02:39
10:59
RodrigoMFitbit
Can I re-order the exercise list? I only do workouts and cycling and these are way down the list.
A real pain to set up before I begin to exercise.
Best Answer01-02-2024 09:28
01-02-2024 09:28
Sadly, you can't. But once you start recording your most-used, they show up at the top. The most-recently-used list on mine has 5 listed, but I'm not sure if that's the max before you get to the 'MORE' button.
01-02-2024 09:28
01-02-2024 09:28
01-02-2024 10:43
01-02-2024 10:43
01-04-2024 11:01
01-04-2024 11:01
@mikey_pdx Thanks for your input and explanation.
@Pit-prop Nice to see you in the forums again. Thanks for reaching out about the exercise list on the Fitbit Charge 6.
All of the exercises are now listed on the device. The list is sorted by frequency. The most used activities will show up at the top. It just takes a bit of patience. Thanks in advance.
