Hi, @ranjitham21 , if your display seems to be fading, it is usually a good idea
- to check the settings menu on your Fitbit (instructions are here (make sure ‘dim screen’ hasn’t got accidentally turned on!)
- to give your Fitbit a restart
- to change your clock face. Instructions are here . (If that improves the issue, then it is fine to return to your previously chosen clock face if you prefer(
- keep your Fitbit battery topped up by charging little and often.
Usually one of these steps will solve this issue for newer devices like the Charge 6. A fading screen can sometimes be a fault for much older Fitbits, due to natural and expected age of battery deterioration.
