11-27-2025
01:04
07:43
HorareyFitbit
11-27-2025
01:04
07:43
HorareyFitbit
After driving my tractor for a day the app decided I had done nearly 30k steps and burned nearly 8k calories. I used to change activity to driving and it was problem solved but now I can't seem to find driving as an option in activities. Is there any way to change this? If not the fitbit is pretty much useless to me
Best Answer11-27-2025 07:20
11-27-2025 07:20
Hi @RustyG026 A warm welcome to the Community! Thank you for your message and feedback.
For you to know the driving option is not available on the Charge 6.
But let me invite you to post your comment as a suggestion in our Product Feedback board in the Fitbit Community. This is the best place to raise new ideas and comment on other members' suggestions.
If a similar suggestion has already been made by another member of the community, you can vote for their suggestion and add your comments.
11-28-2025 14:13
11-28-2025 14:13
Hello @RustyG026
Unfortunately, the Driving activity hasn't been working right for a while now. Users have reported that even if they are able to select Driving as an activity, it no longer removes the erroneous steps tracked.
As far as I know, the team is aware of this issue. However, I haven't seen or heard any update as to when this issue will be fixed.
11-30-2025 09:15
11-30-2025 09:15
Is there any way to manually delete steps and or calories burned? If not there is not going to be a lot of point me using my fitbit any more
Best Answer11-30-2025 13:29
11-30-2025 13:29
Hi again @RustyG026, is nice to see you around!
I understand what you are going through regarding the amount of steps that are registered on your device.
I can recommend you this following article for you to read and be able to understand the processs you want to do in a better way. How to add, edit, or delete Fitbit data & activities
And thank you @RiekoC for allways sharing your knowledge to support our Community!
12-01-2025 07:11
12-01-2025 07:11
Cheers for your help
12-01-2025 10:53 - edited 12-01-2025 10:55
Hi, @RustyG026 , logging “driving” was an old “work around” from the days when Fitbit did not allow you to delete data. It is now possible, as long as you can identify the time period when the false steps came in. The steps you need are:
in the Fitbit app, tap the Steps tile.
Manage data
Delete Data.
I hope this helps and you can solve your issue this time and moving forward.
12-03-2025 11:19
12-03-2025 11:19
Hello @RustyG026
Just to add to Julia's reply: The process she outlined will give you the following options to delete steps:
