11-10-2025
15:17
15:29
StefanieFitbit
11-10-2025
15:17
15:29
StefanieFitbit
Thank you for your patience as you waited for the firmware update.
This update includes key fixes for battery and display issues, along with new clock faces for Charge 6.
Please keep an eye on the Fitbit mobile app for the update notification as it continues to become available to all users, beginning this week.
Thank you for your continued support and patience!
12-28-2025 14:27
12-28-2025 14:27
You might be better off, depending on how it works now. Mine updated and now it is having problems with the sleep metrics. They usually show up at some point during the day, but are mostly 0-5 for a while after I get up. SO disappointed in this Google product.
Best Answer12-28-2025 14:35
12-28-2025 14:35
Best Answer12-28-2025 16:59 - edited 12-28-2025 17:37
2 major issues,
Best Answer12-28-2025 17:23
12-28-2025 17:23
I finally got the update and did it, and now I have a grey screen! I've done a soft reset twice and changed the clock face and it's the same. What was this update supposed to do exactly?! It took my weeks to get it to work because I didn't know it doesn't work on tattooed skin, unlike the inspire I upgraded from and now I can't even use it to tell the time!
Best Answer12-29-2025 15:35
12-29-2025 15:35
Got it hate it. Nothing works anymore. The only stats I have now are steps
Best Answer12-29-2025 15:37
12-29-2025 15:37
Finally got it and now I have no data for Health metrics or sleep.
Best Answer12-31-2025 01:08
12-31-2025 01:08
So the new clock faces...
The vast majority of users were crying out for an adult clock face. Well we sort of got one, but the designers just couldnt resist doodle meddling a teen y weeny bit could they 😄 The only usable one is 'kinda' ok but even THAT has what looks like a greasy fingerprint on it?! For the umpteenth time of asking couldnt we have just one normal face? Akin to the older versions??
12-31-2025 05:11
12-31-2025 05:11
I like "Momentum" with all the data, but why couldn't they make it customizable like some of the others? All I want is date, time, heart rate, miles, battery, on one screen. Would have been easy to have that option on that face.
Best Answer12-31-2025 10:14
12-31-2025 10:14
Might be they will do that with the Pixel watches, if they haven't already.
Best Answer01-08-2026 08:05
01-08-2026 08:05
Updated my fitbit this morning, 8 hours later it is bricked. This is a recurring issue. My charge 4 bricked its self, then my charge 5 did the same (including the two or three replacements I was sent before a gave up on the things) and now three months into owning a 6, that has died! What is wrong with your products?
Best Answer01-08-2026 11:21
01-08-2026 11:21
I have the same issue and my Fitbit is 6 minutes fast. How you check your firmware update and do the update?
Best Answer01-08-2026 12:15
01-08-2026 12:15
Best Answer01-09-2026 23:00
01-09-2026 23:00
After leaving it for 24 hours it now turns on again but the battery drains it's self flat in less than a day
Best Answer01-09-2026 23:38
01-09-2026 23:38
I did delete the app and reloaded it. Nothing. Still don’t see where to get the link. I clicked on the link I thought was in your post but don’t see it. Others are saying they received an email I don’t see it. Is there a way to communicate with google Fitbit support I see only this forum but no software to download
Best Answer01-10-2026 14:04
01-13-2026 04:22
01-13-2026 04:22
My Charge 6 stopped syncing last week, so I went through the rigmarole: Googling the issues, deleting the app, reinstalling, updating, reconnecting. It worked for a few days. Today it disconnected again. I was able to restore the connection by restarting the watch, but... is there still a problem?
Best Answeryesterday
yesterday
Pleased to advise that along with Fitbit support my issue seems to have been resolved. I will monitor and keep my fingers crossed. I have been advised of an update but have been unable to find?
Have to say that I was pleased with the Fitbit agent who communicated. He help address the problems with constructive suggestions and proposals.
16 hours ago
16 hours ago
Hi. My Charge 6 had no battery issues at all until a few weeks ago when I installed firmware version 66.20001.220.31 - now my battery life is inconsistent, lasting between 2-4 days, instead of the previous 6-7. It seems worse when the battery percentage is at 40% or below... When the battery can the fully drain within only a few hours. I've tried a restart to try to fix it, but to no avail.
Are there any known bugs with firmware 66.20001.220.31?
Thanks
