07-17-2024 14:57
07-17-2024 14:57
I have a fit bit charge 6, ,just 3 months old , the gps has never been accurate , I have done all the trouble shooting suggested by support who tell me they are escalating the case, factory reset , delete and uninstall, re install.everytune i use chat or help I get the same response , the watch in my opinion is faulty , is this common with fit bit
So frustrating
Best Answer07-18-2024 16:49 - edited 07-18-2024 16:52
I got mine on the 12 of may. The GPS does not work correctly. Looking at this forum and the youtube reviewers they all say basically the GPS does not work well on the charge 6. I personally am not that bothered about the GPS but if bought it on the basis of GPS I would be unhappy. I got mine for sleep tracking so although some issues reasonably satisfied as the sleep tracking is good
