07-18-2024
19:43
08:48
CrisVillaFitbit
07-18-2024
19:43
08:48
CrisVillaFitbit
Hi,
I just bought a Fitbit and need assistance setting it up.
I am 51, female, height 165 cm, weight 65.5 kilos.
In Fitbit settings> (Select) Nutrition & Weight> (Select) Food
There is two choices
When I select 1 there is four plan intensity options:
This is where I am confused. As when I chose an easier/medium/kinda hard/harder option the app automatically enters a number in Option 2 - I want to set my own goal.
These figures are extremely low and not achievable.
If I choose 1 Help me set up a goal do I ignore the number given in 2. I want to set up a goal?
If I should ignore it why does Fitbit change the number for the easier/medium/harder settings.
Thank you.
Moderator edit: edited title to clarity.
Best Answer07-19-2024 08:52
07-19-2024 08:52
Welcome to the Fitbit Community, @Queensland.
Thanks for letting me know about this situation with the plan intensity using your Charge 6.
You're right, in the option 1 (Help me set up a goal) the system will automatically set up the goal by putting the stats, in this case, you need to set it up manually in the option 2 (I want to set up my own goal).
You can check more information here if needed.
