01-16-2024
20:53
06:36
CrisVillaFitbit
01-16-2024
20:53
06:36
CrisVillaFitbit
I have restarted 12 times. Charged for 6 hours trying to update my charge 6. Everytime there is an update my tracker becomes unresponsive until software updates. A usless piece of junk until by some miracle it updates finally. This is the 3rd time this has happened.
Moderator edit: edited title to clarity.
Best Answer01-17-2024 06:39
01-17-2024 06:39
Welcome to the community, @BoydLakeCrew.
Thanks for letting me know this situation in regards to your Charge 6 and with its update.
Can you confirm if this happens whenever you are updating the Charge 6 or before you start the update? I just need all the details so I can check it further. Also, you can check here about how to update it efficiently, probably you know already but a double check it is worth.
Best Answer01-17-2024 11:25
01-17-2024 11:25
When it tries to update the logo and status bar appears. Then it looks like it goes to 100% then screen goes blank and the app says update failed.
