My charge 6 vibrates for calls but not for other notifications. I've tried resetting charge 6, resetting phone, turning Bluetooth off and on, checking notification settings, unpairing and pairing watch, checking DND and sleep settings. Nothing seems to work. It used to when I first got, but I've had it about a month and it's stopped.
I just had the same issue. It finally started to vibrate on my test texts again after I restarted the fitbit, but I see you tried that. Like you, I tried turning every setting off and back on, pairing, etc, with no luck. After all that, the restart of the fitbit seems to have resolved it. I suggest you try restarting your fitbit again, now that you've reset your setting in the app.
Best AnswerDitto for me. Was working fine just a few days ago and suddenly it’s not vibrating. My husband had knee surgery on Tuesday and I need to rely on getting his texts immediately. I’ve tried everything too … it’s so frustrating
Best AnswerThank you for this info … I will also try this. No data is lost correct?
Best AnswerRestarting my fitbit again did the trick. Thanks
I restarted my fitbit again and it worked. Nothing is lost. Just need to select restart on your charge 6 by scrolling up to settings then down to restart at the bottom. Hope it works for you too.
Correct. No data was lost
