06-03-2024
00:04
20:34
EstuardoFitbit
06-03-2024
00:04
20:34
EstuardoFitbit
I’m looking for a watch that counts all my steps for the day, and tells me how much calories I burn when I go for walks that’s the biggest thing for me and I was wondering if that’s what a fit but does also how big does a fit bit come bc my wrist are bigger than a average persons I would say
Best AnswerHi @shrahbo There is a quiz to take to see which one would best suit you - click to take it
For those with larger wrists, Amazon has a lot of sellers who list band extenders, which might be helpful.
Each Fitbit device in the store has a size chart and it can be printed out to see if it would fit. click to see the Inspire 3 size band. If you want to check other sizes, which generally run the same, just look at the device information specs.
Fitbit tells you have many calories burn and counts steps. Fitbit also estimates how many calories you burn in a day. You can enter the food you eat and it gives you a balance. It comes with 2 watch straps. For me the watch straps are not ideal as am just in the large size band which means its has lot of extra. If you have large wrists I am would think it will fit well with the large strap. Having said that I found the strap caused redness and I dont like the fold under design of the strap that came with it. I would not worry to much about the trap. You can get many different types of straps on Amazon for little money. I Bought and elastic strap and now a leather one and will probably get metal one next. I am going to get my next ones on Ali express as they are cheaper still but amazon is like 10 for 3 straps. The good thing with fitbit as so popular so many straps you will find one that suits you. The sleep tracker is very good the best of all trackers according to a youtube PHD that tests them against medical devices. If you use other devices like smart scales fitbit may also accept there data. I found with my smart scales that had for 4 years would work in fitbit with my old Huawei tracker the scales were not compatible. Although for price you get more with Huawei the sleep is not so accurate and cant get as many straps. For steps I would think fitbit is the most widely used.
