Recurring alarm not updating
So I updated my Charge 6 this morning (on Android) now the repeating alarms are showing grey with a cross and the only way I can have them on is to have a 1 time alarm any ideas?
I've restarted the watch uninstalled the app on my phone and check DND and sleep mode and neither are on.
89 REPLIES 89
I am having the same problem. For me it seems to be completely random when the alarms that are on turn gray or yellow. I just got my fitbit in March and it has done it the whole time.
since factory resetting my inspire hr 3 it works as normal.
the alarms work.
the icons are gray if the time of the alarm is past the current time for
the day.
orange is for will trigger.
red is disabled I think
Great News!
I was apparently totally wrong in my last update ( I've since edited it!). Support will tell you factory reset and it does actually work.
The alarm will still look broken and you will lose that day's activity, but the recurring alarm did start working after the factory reset and resync. Huzzah!
You are the first one to be positieve.
Mine is getting worse by the day.
Alarms still won't work properly (overslept 3 times) and as of today the vibration with massages or set goals (steps) doesn't go off.
Getting my Samsung ready because i'm tired of this &#^=>÷+!(=[÷
Mine literally locked itself and stopped being able to connect to my phone after I did this. Apparently it's a common issue as well.
Definitely get your money back if you can! This is a known warranty style issue.
Happy day here… woke up this morning to find all my recurring alarms are now back to their normal icons—no more scary gray Xs instead of clocks! So I am guessing an update was pushed out that finally corrected the problem. Take a look on your devices to see if you, too, have been blessed by this miracle!
Mines definitely not back to normal
Fix the reoccurring alarm please, I have a charge 6 and it is all up to date plus I restarted it.
Just a little update I have seen a couple of people saying they work so gave it a go and I can confirm that despite being grey and the X in the middle of the clock they do stay on as repeating alarms.
So its not a problem just the worst design given the other alarms are red for off and yellow for on (which I am pretty sure how the repeating alarms looked before this update).
