11-23-2023
06:38
12:15
RodrigoMFitbit
11-23-2023
06:38
12:15
RodrigoMFitbit
I want to be able to monitor my heart rate while exercising eg walking. But I can’t get back from the walk screen to the Home Screen without ending the walk.
And if I don’t tell it I’m about to take a walk, it senses I’m walking and again stops showing me my heart rate.
Is uninstalling ‘exercise’ the only way to be able to see heart rate all the time?
thank you
11-23-2023 12:17
11-23-2023 12:17
@MB115 Nice to see you in the forums again. I will gladly help you check your heart rate meaurement while you exercise. I appreciate the explanation.
While the exercise is running on your Fitbit Charge 6, tap on the screen. That will allow your to cycle through the different stats; steps, distance and hear rate for example. Give it a try on your next training session. That way you can keep the exercise app installed.
11-23-2023 12:17
11-23-2023 12:17
12-26-2023 16:50
12-26-2023 16:50
I have the same issue, but tapping thru stats does not show heart rate
09-20-2024 00:00
09-20-2024 00:00
Hi, same issue here. My old fitbit charge 2 shower it, the charge 6 Shows distancing, time, etc but NO heartbeat while exercising. Can you please check and clarify?
Best Answer09-20-2024 00:57
09-20-2024 00:57
Found it, as described above! Thanks anyways!
