01-23-2025 07:11
01-23-2025 07:11
I tend to wake up a LOT at night, and this causes my fitbit to determine that I slept much less. For example, I will go to sleep around 11pm, and wake up around 2am. When I fall back asleep it forgets any of the previous sleep I got and will only track 3am-6am for example. When I try to manually log sleep, it tells me it cannot do that because it already has sleep logged for that time (even if I make sure to choose times that are not logged.)
Is there any solution to this?
Best Answer01-23-2025 10:24
01-23-2025 10:24
Hello @bokodlo1
Like you, I've experienced where my device doesn't track my sleep in a single log.
Since your app is giving you the message that sleep was already logged for a period & you don't see it, go back to the previous day and see if there's a log that captured your sleep from the evening before.
I was having a similar issue where I was trying to edit my sleep log and kept getting the message that there was already a log for that time period. However, I didn't see one on the sleep page. It finally dawned on me to check the sleep page for the previous day and there it was under other sleep. Once I deleted that log, I was able to go back and edit my sleep log to capture the full night.
