03-16-2024 06:45
03-16-2024 06:45
My pedometer app is very accurate on the steps count and the Charge 6 Fitbit count is very inaccurate on my treadmill. How can I correct this?
Best Answer03-16-2024 12:52
03-16-2024 12:52
Hello @Eleanor1940
Wrist worn fitness trackers, including Fitbit, use accelerometers and arm movement to track steps. A pedometer app will use your phone's accelerometer(s), but don't require arm movement to track steps.
If you are holding onto the hand rails while you use the treadmill, you won't be getting as many steps since arm movement is limited. This is similar to what users see on their step counts when they push shopping carts or strollers.
Some users will attach their Fitbits to their ankles when they use the treadmill so they get a more accurate step count. However, when they do this, they are not getting heart rate tracking.
This help article helps explain how the Fitbit device calculates daily activity, including steps (<-- click link)
03-16-2024 13:09
03-16-2024 13:09
Best Answer03-16-2024 15:28
03-16-2024 15:28
Adding just a bit to correct answer by @RiekoC , note that when you lose heart rate data, you also lose accurate calorie burn and zone minutes for that time, as calorie burn is based on heart rate. It's a trade-off which is more important to you, though some people claim they can still get heart rate from ankle wear with careful positioning and tightness. A strap extender might be required, which can be bought on Amazon. Alternatively, if you can just hold onto hand rail with only one hand and let fitbit arm swing free, you get both, but not worth it to give up safety.
03-17-2024 09:05
03-17-2024 09:05
I also find Charge 6 very bad at steps counting. Today, it undercounted little over 5000 steps during my run and steps came short by 11% (far beyond acceptable margin of error). That wasn't the case with previous models I owned 🤷 This also seems to be the reason why my running distance is always shorter than real one.
Best Answer03-17-2024 10:37
03-17-2024 10:37
Best Answer03-17-2024 11:31
03-17-2024 11:31
Hi @Eleanor1940
I believe that notification is under the Fitbit Settings menu.
Although I don't think it's necessary, I usually do a manual sync from the Today page after making a settings change.
Best Answer03-17-2024 11:40
03-17-2024 11:40
Best Answer03-17-2024 11:54
03-17-2024 11:54
Hi @Eleanor1940
I've only gotten a notification when I hit my daily goal (100%) and it's a very brief one.
Although there's no guarantee that this will work, another thing you can try is to clear the cache for your Fitbit app from the app settings on your phone.
Best Answer03-17-2024 13:01
03-17-2024 13:01
@RiekoC my Charge 6 gives me notification for every time I reach target for any multiplier.
03-18-2024 12:23
03-18-2024 12:23
Best Answer03-18-2024 13:27
03-18-2024 13:27
@Eleanor1940 I have no idea. It was always working like that for me. In fact, I'd like to turn that off because those notifications are annoying (yesterday, got it 4x during my run for each 10k steps).
