Since I purchased the 6 ( I have had many fitbits prior) it just doesn’t sync!!! I have to remove the Fitbit and reinstall almost daily in order to get my stats! And I have a premium package! Any suggestions as to what the problem might be?
I have a charge 2, 4, and recently got a Charge 6. It will not pair with the 2 and 4. When I get it paired it removes the 4.
when paired, it won’t stay paired (charge 6). When I wake up,on the morning it is not paired. It takes a while to pair it, then throughout the day, it becomes unpaired several times. It is so annoying and time consuming to continue to pair it several,times daily.
My Charge was good, still works and is fine. The Charge 4 is ok, works good, but the display cannot be read outside unless I’m in a very dark, shade spot. The 6 is the worst. The watch ir great, with options, it won’t stay paired.
in addition, my wife has a Charge, 2, 3 and 6. So far the 6:is fine for her.. The display cannot be read, seen, inside or out on the 3. Like my Charge 2, it works pretty good and has no problems.
