01-31-2024
05:53
08:24
LizzyFitbit
01-31-2024
05:53
08:24
LizzyFitbit
Quick tip to fix - I bought my Charge6 1 week ago and experience black screen suddenly today even though it is fully charged. I chance upon a prompt that I need to upgrade the system. After upgrading, my blank screen is fixed. Above tips for those new user experiencing the same problem. Cheers!
02-04-2024 08:44
02-04-2024 08:44
@Lilian77 Welcome to the community forums.
I'm glad you sorted this out and thanks for sharing the steps that worked for you. Your post is definitely helpful and I'm sure other members will think the same.
In case you have some spare time, I'd like to invite you to visit our Health & Wellness board where you can find inspiring stories, create your own topics and motivate other members to reach their goals. Have a good day!
Best Answer02-08-2024 00:27
02-08-2024 00:27
Hello
I ran into the same problem yesterday of a blank screen, everything is working inside as I can see changes on the app. I also noticed that there was a prompt for and update, so put the Charge 6 on charge and started the update, it said this could take upto 25 minutes and the fitbit diamond logo appeared on the screen. Then it lost connection even though the Charge 6 ad my phone were very close to each other, restarted the the update, this time it told me it would take upto 40 minutes to update, about a minute later it told me that the update was complete. But my screen is still black, according to the app on my phone the Firmware Version is 66.20001.202.94.
Can you please confirm this is the latest version?
Can you suggest anything else that I can do to sort the problem?
I have had my Charge 6 since the general release in September, and I haven't had any other problems with it until yesterday, I am also in the UK incase that makes a difference,
Thanks for any assistance anyone can give.
Best Answer02-08-2024 13:45
02-08-2024 13:45
02-09-2024 01:45
02-09-2024 01:45
Thank you for your reply. I tried restarting it last night but that didn't make any difference.
This morning I tried synching my phone and the Fibit logo showed with a progresive blue line under it. Still didn't have anything on the screen, just tried a firm push and slide, then the screen came back, now responding with the normal pressure and tapping the screen.
Confuse.com 🙂
Andy
02-23-2024 14:47
02-23-2024 14:47
@Lonewolf1507 It's good to see you here. @Lilian77 Thanks for your continued help.
@Lonewolf1507 Thanks for sharing detailed information about your experience with the Charge 6 and the steps that you've tried. While this was an odd behavior, I'm glad it started working again and I hope you can keep crushing your goals.
By the way, I'd like to invite you to visit our Health & Wellness board. You can make new friends and start your own topics. Have a good weekend ahead!
