03-26-2025 19:12
03-26-2025 19:12
I received the firmware update to my Charge 6 today and it has ruined my experience with the watch completely. I moved software to my iPad to sync/connect my Charge 6 because I don’t want to allow the app to have location services ALL THE TIME on my cell phone, which is another unacceptable recent change that I consider borderline stalking. I don’t carry the iPad with me and the watch was not demanding a constant connection to a phone or the iPad until today. Starting after the update, it began blocking my view of my heart rate on the watch to alert me constantly that it’s not connected to a cell phone. It stops doing it when I open the app on the iPad so the watch can connect to it, so this is definitely the problem and it is brand new with this firmware update. This has made the watch useless garbage to me because I cannot just track my heart for my health.
Please tell me how I reverse this update to fix my watch. I really don’t appreciate being required to allow Google to stalk me in order for my watch to work properly.
03-27-2025
05:27
20:32
EstuardoFitbit
03-27-2025
05:27
20:32
EstuardoFitbit
I know right I did the update yesterday and it’s been a disaster. Same issue you are having. My charge 6 steps are not matching the app but they are calibrated to my exact stride. The app doesn’t sync. I have done all the troubleshooting including removing the tracker and uninstalling the app. Nothing has worked. So annoyed second major issue in four months.
03-27-2025 09:00 - edited 03-27-2025 09:00
Hi @Saebs and welcome @mostlyharmless2 to the Fitbit Community! It's great to have you here!
Let me help you with the latest update installed in your Charge 6.
Please note the Fitbit app requirement to access your location is needed for better performance. It may arrive that an app update has made some changes to your current app settings:
This being said i recommend that you check out our help article Why is the Fitbit app prompting me to turn on location services?
Best Answer03-27-2025 12:01
03-27-2025 12:01
If your response to "this is unacceptable" is "check out this link to why this is necessary" for something that clearly wasn't necessary just a few days ago, then I won't be upgrading. I'll switch to a different brand when my current model dies, which shouldn't be much longer, given fitbit's past track record.
Seriously, I can't think of any other Bluetooth device that requires GPS to be on, the idea that there is simply nothing to be done is the most obnoxious gaslighting I've ever experienced.
03-27-2025
12:51
13:36
AndreaFitbit
03-27-2025
12:51
13:36
AndreaFitbit
Hi I have location services turned on but would appreciate the help with getting my Fitbit working again pleasr
Moderator Edit: Formatting.
03-27-2025 14:21
03-27-2025 14:21
Well, don't switch out your Fitbit because you think some other brand will not require Location (!!)
The problem is that any non-ancient Android versio forces you to allow Location before it will allow you to 'pair' (connect) any Bluetooth device.
There's a long and contorted song and dance as to why, which breaks down into:
They don't fix or revert any of this, being asked for a long time, nor of course comment. I believe you are able to turn off Location Services on your phone _after_ you've paired, but this is also made unlikely by apps still bothering you with notifications for their 'need', not to say inconvenience and forgetfulness all around.
In short, it's Google via Android, not Fitbit at fault here, and the long tier of marketing etc. 'drive' people, but you can't avoid it by choosing another fitness device, which will in all likelihood do just as your Fitbit does.
Best Answer03-27-2025 14:38 - edited 03-27-2025 17:42
@saebs, two thoughts, after reading yours and the original complaint from @mostlyharmless2 here.
Best Answer03-27-2025 16:49
03-27-2025 16:49
In case anyone else is having the same problem, I did figure out how to fix the notification that was blocking my heart rate. Look into settings on the watch, then display settings. Scroll to the bottom of display settings and look for “status tray” and turn it off. I don’t know if “status tray” was already there and the update just turned it on by default, or maybe it’s brand new. Either way, it fixed the notification that blocked my heart rate, thank goodness. Looks like I can continue to use the watch…until the next update…
03-27-2025 16:56
03-27-2025 16:56
That is downright weird -- like something from another watch which erroneously got included with the Charge 6.
I wonder how you found it 🙂
And don't see anything like that on mine, which is still running 210.26, having not been offered an upgrade.
03-27-2025 17:06
03-27-2025 17:06
I think Fitbit and Google are the same entity now, since Google bought Fitbit. It’s ridiculous to be forced to allow my watch to stalk me by accessing location services ALL THE TIME, when I never use location services for the watch in any way. Fitbit needs to change this. It was never a problem until the last Fitbit software update so I don’t buy the gaslighting either. I have put the Fitbit software on my iPad instead, because the Charge 6 connected to an iPad doesn’t seem to care if they can locate me 24/7; at least not yet. This setup works fine to sync to at the end of the day or in the morning, if I’ve slept in the watch. I also solved the problem caused by the Fitbit watch firmware update by turning off “status tray” in display settings, so the notification that was blocking my heart rate is now off. Other than all of the other Fitbit idiosyncrasies, I think I’m okay UNTIL the next update.
Best Answer03-27-2025 17:13
03-27-2025 17:13
Best Answer03-27-2025 17:32 - edited 03-27-2025 17:33
Ah, I think I see the link now, between that notification and your blockage -- it's because you resist the Location, thus the notification blocks the Fitbit actually sending your fresh data.
Just for clarity, again, it is Android which has long made the whole Location requiring mess -- and very deliberately, years ago. They are not going to unwind this, pretty apparently.
So if you don't want it, I guess you'd have to move off Android phones, which leaves Apple, and this applies to any fitness device you might keep or choose.
In any case it's essential that Fitbit condition this new firmware/s notification on missing Location, to avoid the blockage for iPhones, unless they already have. And change it also so it doesn't actually block functions on Android. That's a very important flaw that you've found.
The new firmware has documentation about 'necessary updates on Bluetooth', so I hope that's not about this same forcing. It just might be, given the obscure way the original block without Location has been explained for Android.
And yes, both Android and Fitbit are under Alphabet, Google's corporate.
17:34
13:38
AndreaFitbit
03-27-2025
17:34
13:38
AndreaFitbit
Hi thank you for that. I will check my IPad and IPod to see if Fitbit is connected. And see how that goes. Fingers crossed.
I have always had always had an IPhone and these issues occurred since the firmware update. Its @mostlyharmless2 who is on Android.
Sent from my iPhone
Best Answer03-27-2025 17:46
03-27-2025 17:46
So why does a gamepad, headphones, and any number of other devices not require location services to be enabled? It would be one thing if this was just asking for permission, but I literally cannot turn off my phone's GPS (which could be saving me some significant battery usage) without it disrupting the connection.
What gives? What magical information simply cannot be transmitted through Bluetooth as a high bit rate audio transmission and NOT require a GPS connection?
03-27-2025 20:04 - edited 03-27-2025 22:27
I believe the distinction of what items are set to require Location depends on the generation of Bluetooth in use -- that the restrictions were set on Bluetooth LE, which is preferred these days for its Low Energy (battery saving) and other properties.
Whether a device follows that idea carefully or not probably determines whether given earphones etc. hit the requirement or not.
As far as the explanation given for the restriction, that a rather determined adversary might in some cases be able to derive location from Bluetooth itself, thus the need to insist permission be given for location if Bluetooth is turned on, well...that's a topic full enough of questions, I suspect.
Best Answer05-27-2025 12:36
05-27-2025 12:36
Did this to me yesterday! I have been on the phone for 45 minutes completing all the steps I already completed. My charge 6 will not pair with my fitbit app. It will not turn on. I can still hear the vibration. All I get is an offer for 35% off. It worked just fine before trying to install the update for the watch. DO NOT INSTALL IT!
05-27-2025 12:38
05-27-2025 12:38
I have been a Fitbit watch user since 2022. My husband has one and this last Christmas I bought my 19 year old son one. With that, I have bought two for myself and I have had two replaced due to issues. My husband has had the same issues.
This time my Fitbit is over a year old so no longer in warranty. It should last more than a year.
12:36
13:29
MarioSFitbit
05-28-2025
12:36
13:29
MarioSFitbit
I know it’s ridiculous. I contacted Fitbit support who just stopped replying which I later found out was because they believed it was a MyFitnessPal issue due to older firmware. MyFitnessPal were great but confirmed what I already knew I had updated to their most recent update. So NO that was not the issue. I have essentially stopped using my Charge 6 except as a comparison to my Apple Watch. Based on this experience since the update and the inability to fix and total lack of support I will never buy another Fitbit again.
Moderator edit - formatting
