01-02-2025 19:35
01-02-2025 19:35
Given that Fitbit has my location data, why doesn't it take account of altitude and adjust heart data to reflect changes in altitude. Over the holidays I was in higher altitudes, between 4500 and 8000 feet above sea level (up from 1200 ft where I live). Fitbit app kept telling my my resting heart rate was high, blood oxy was low, readiness was low, etc. However, this is simply an effect of being at a high altitude. Why doesn't the programming reflect this change due to altitude?
Best Answer01-03-2025 08:12
01-03-2025 08:12
Hi, @SteveCar! I'm guessing that would be a pretty complicated change, since it would have to track your location all the time, figure out where you typically live and what the altitude is, then correlate that to where you are and what the change is. I've seen people complain about it going the other way, too, when they're from somewhere like Colorado and visiting the coast. I'd say it's more of a point of interest and move on, although you're welcome to add the suggestion to the Product Feedback forum.
MakMak | Community Council
01-03-2025 09:31
01-03-2025 09:31
Hi @SteveCar! I'm a physiologist and those are real changes, not an effect. Physiologists use oxygen partial pressure when describing altitude physiology. Effective percent oxygen makes more sense in everyday conversation. Air is 20.9% oxygen at sea level. Your effective oxygen percent is 17.3% at 4500 ft and 15.4% at 8000 ft. Your Fitbit was telling you the truth.
Laurie | Maryland
01-03-2025 10:32
01-03-2025 10:32
