07-05-2025 06:29
07-05-2025 06:29
My charge 6 has started listing wrong sleep hours, and 0 rem hours and 0 deep sleep hours, it’s showing 3 + hours sleep, I have restarted the watch no change, what’s up
Best Answer07-05-2025 12:58
07-05-2025 12:58
Hello @SunsetRunner
Have you tried editing your sleep log in the Fitbit app with the correct sleep & wake times? If so, does the app update with your sleep data?
If you haven't edited your sleep log before, this help page (<-- click) has the steps to follow.
Best Answer07-09-2025 09:53
07-09-2025 09:53
The sleep tracking on my FB6 has gone haywire as well... starting around the end of last month. The scores are wildly wrong and it's showing huge periods of wake time in the middle of my sleep. In addition, The main sleep tile in the app does not show the same time or score that is shown when you drill down to the actual sleep data. For example, it may say that I had 8 hours of sleep with a score of 82 in the main sleep tile, but when I go look at the sleep data for that night, it will show a completely different time and score. Previously, they showed the same numbers, and if I edited the sleep log, it would show that it was recalculating my sleep score. It no longer does that either... and the score isn't updated until I go back to the main screen on the app. Very frustrating, and yet another in a long list of things breaking over the period of time I've owned this tracker - without any explanation or support from Google.
