I am a bad sleeper, this is why I bought a device to track my sleep. If I had no sleep issues I would not need tracking.
I wake up several times a night. If the first one occurs within 1 hour I asleep then Fitbit device do not start recording the sleep. If it started, but I wake up for more than a couple of minutes, then it closes recording, and the whole cicus starts again.
I would be satisfied even if it recorded by my sleep schedule and displayed correctly the periods, also if it started or ended with 1 hour awake period.
How could a bad sleeper as I am get usable sleep infro from an advertised premium Fitbit device?
Best AnswerIt might be because of when you wake up. Fitbit does record sleep, but only after 2 hours of non-movement. Once the device hasn't moved for 2 hours, it then retroactively records the information from that time frame.
one cruise ship at a time!ThankYou DramaQueenDiva,
Indeed, this is the problem, not the solution. (Actually 1 hour, as I have written.)
