For direct sunlight situations, add an ability to boost screen brightness temporarily, i.e. one-time event, through an easy to access while exercising method e.g. through a screen tap/scroll sequence. Enable the user to determine the preferred method in the Settings on the Charge 4 device.
					In direct sunlight it is often very difficult, if not impossible, to see the display, even while shielding with a hand and a great deal of focus.  This presents a safety issue, since the level of focus and concentration needed detracts from being attentive to surrounding situations.  Also, it just gets to be a bit frustrating not seeing the info.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
