02-26-2025 05:49
02-26-2025 05:49
Yesterday the language changed on my son's Fitbit Ace LTE and I cannot figure out a way to change it back. The Fitbit Ace app doesn't have much for settings.
Best Answer02-27-2025 12:07
02-27-2025 12:07
Hello @bork96
I believe the language setting is on the Ace device itself.
This help page has the steps to access Settings on the Ace device (<-- click link). Check Display to see if selection for language is there.
03-06-2025 13:38
03-06-2025 13:38
I am having the same issue. It also disconnected from the app so I can't see it and I can't pair it because the language is a character-based one so I can't figure out how to get to the correct screen.
Hoping someone from Fitbit sees this as I've tried calling their support line multiple times but I always get a "we can't answer your call right now" message and then the system hangs up. Very frustrating.
Best Answer03-06-2025 14:34
03-06-2025 14:34
Hello @ktmalueg
Please submit this issue using the Feedback option in the Ace LTE app:
Please let us know when you submit the feedback. I'll see if I can get someone from the team to follow up.
03-11-2025 14:47
03-11-2025 14:47
My son just did this, at least changed the keyboard language. Long press the space bar (bottom center button) and the language menu should come up. Choose English and then press the side button to get back to the keyboard.
Hope this helps.
03-13-2025 11:40
03-13-2025 11:40
Thanks. I was able to get to the keyboard but when I do the long press the options it brings up are in another language and I can't figure out how to change the language. I tried tapping each but nothing happened. Great idea though.
03-13-2025 11:40
03-13-2025 11:40
Hi Rieko -
I submitted my feedback through the app. Thanks!
03-13-2025 13:28 - edited 03-13-2025 14:06
Hello @ktmalueg
Thank you for letting me know that you submitted feedback. I'll try to reach out to the team and let them know.
Update: Response from one of the team members:
The quickest way to fix the problem, especially since the parent's phone can no longer communicate with the Ace device, is to do a factory data reset. This process will delete the data on the device. The data should be restored when you set up the Ace again for your child.
Since the Ace is displaying in another language, here are some basic swipe, press, and tap instructions to get it to the right setting for this. It's usually
This help page also has the steps for doing a factory data reset (<-- click link).
After the factory data reset is completed, you should be able to set up the Ace device again. This page has the steps for setup (<-- click link) in case you need them.
Please let us know if this worked for you.
04-23-2025 21:40
04-23-2025 21:40
I was just able to fix this by using the translate feature on my phone. The steps: long press top button, bottom option is settings. All the way down is system. 5th from bottom is language. Very tedious doing this by taking pictures in google translate, hope this helps someone!
04-25-2025 10:48
04-25-2025 10:48
Hello @Lucielou2
Thank you so much for taking the time to share the steps that you used to fix this problem. I'm sure this will help parents & guardians who experience this issue.
