07-04-2024 14:17
07-04-2024 14:17
Hi. Anyone knows how to disable theater mode? Wanted to wake watch up by tilt but grey out due to theater mode being on. Thanks
Best Answer07-05-2024 06:44
07-05-2024 06:44
Hello @MacMac and welcome back to the Community. I know that Apple Watches have a theater mode. It is similar to Fitbit's sleep mode (screen wake with wrist movement is disabled). I've gone through all my screens and don't see it. There are no results for this feature in the Fitbit Ace LTE Help articles.
Can you ask your question a different way and/or include a photo of where you see this?
Laurie | Maryland
Best Answer07-05-2024 07:01
07-05-2024 07:01
Be sure the watch is updated to the latest version. Push and hold the top button, settings, scroll down to system, system updates
Best Answer07-05-2024 08:20
07-05-2024 08:20
Yes it’s up to date and went through all the settings and can’t find theater mode so I can disable it.
Best Answer07-05-2024 08:21
07-05-2024 08:21
Yes very odd if I can’t disable it so I can enable the touch screen to wake and tilt to wake feature.
Best Answer07-05-2024 08:28
07-05-2024 08:28
Have you given the watch a reboot lately? See if that helps.
Best Answer07-05-2024 08:38
07-05-2024 08:38
Yes. Rebooted and even did a full reset.
Best Answer07-05-2024 08:45
07-05-2024 08:45
Please post up a screenshot or screenshots of the messages you are seeing. That will really help
Best Answer07-05-2024 09:35 - edited 07-05-2024 09:36
@MacMac Can you please add some photos and/or screenshots? Just to let you know what is going on behind the scenes, two Product Experts and two experienced users are trying to reproduce your issue. It will really help if we can see what you see.
Laurie | Maryland
Best Answer07-05-2024 09:48
07-05-2024 10:07
07-05-2024 10:07
Do you have developer mode enabled in the family link app? Is developer mode enabled on the watch in settings?
Best Answer07-05-2024 10:12 - edited 07-05-2024 10:13
@MacMac I'm trying to get an answer for you through an internal Fitbit channel. This could take a little while.
Laurie | Maryland
Best Answer07-05-2024 10:17
07-05-2024 10:17
No. I never enabled it and can’t find it on watch nor family link app. Appreciate everyone’s help
07-05-2024 10:19
07-05-2024 10:19
Confirming you did a full factory reset of the watch? Do it again and also clear the app cache and data for the ace app on your phone.
07-05-2024 16:42 - edited 07-05-2024 16:42
Do you have a case ID or did you contact support about the issue?
Best Answer07-06-2024 04:26
07-06-2024 04:26
@MacMac Please file a report using this Ace LTE Help page, if you haven't already done so. It is believed your device has a software issue. You should get a case ID. This will help you get the replacement you need.
Laurie | Maryland
