Hi,
When setting up the Ace LTE for my child originally, it seemed to copy over the credentials for my home wifi network (which I was connected to) at the time, so the watch can use that network.
But unlike say a Pixel Watch, it did not synchronize the entire list of saved wifi networks from my phone to the watch.
So if I want to add a new wifi network to the Ace LTE so that it can use that network for messages/calls/location at times when it has no LTE signal due to being underground indoors, how do I do that? Do I just do it directly on the watch? Or is there a way to do it on my phone remotely?
Presumably the answer is to use the watch.
Thanks
Best AnswerHello @scootley
This help page on Wi-Fi issues (<-- click link) indicates that you make changes to the network from the watch's settings. You just have to make sure that it's a 2.4 GHz network.
The Ace LTE doesn’t sync your full saved Wi-Fi list from your phone like a Pixel Watch does. If you want to add a new Wi-Fi network, you’ll need to do it directly on the watch itself. Go into the watch settings, find Wi-Fi, and connect to the new network from there. Once it’s saved, it should automatically use that network whenever LTE isn’t available. There isn’t currently a way to push new Wi-Fi networks to the Ace LTE remotely from your phone. adding it directly on the watch is the way to go.
